It is currently Tue Jul 29, 2025 10:08 pm
 Post subject: Sides for a cutaway
PostPosted: Fri May 22, 2020 10:38 am
Have I marked this out correctly?
I talked to a very knowledgeable member last night, and consulted Gore / Gilet so I believe I’m going about it right
This is for a 20s L1
Pic of mold is here to help with things
Sides
Body shape
 Post subject: Re: Sides for a cutaway
PostPosted: Fri May 22, 2020 11:21 am
Just make sure you know and mark which is the inside and outside of each piece so you get it oriented in the bender correctly. The photo shows what I think is going to be the outside so that will be placed face down.
These users thanked the author Barry Daniels for the post: SnowManSnow (Fri May 22, 2020 11:30 am)
PostPosted: Fri May 22, 2020 11:34 am
You’re correct
PostPosted: Fri May 22, 2020 8:15 pm
First name: Trevor
Last Name: Gore
City: Sydney
Take care!
If you're using a Fox style bender as shown in the book (mine's a double width one), and those are the outsides of the sides in the pic, they will go face up in the bender for a right handed player. Check out Fig 8-2.
Another tip, but likely too late for this build as you have profiled the sides, is to put any swirly grain where the bending is least. So that "knot" close to the waist may have worked out better if the head end was at the other end of the side panels.
http://www.goreguitars.com.au
These users thanked the author Trevor Gore for the post (total 2): Pmaj7 (Sat May 23, 2020 1:34 am) • SnowManSnow (Fri May 22, 2020 9:05 pm)
PostPosted: Fri May 22, 2020 9:07 pm
Trevor Gore wrote:
Take care!
Trevor yes! I slapped my head when I really registered where that knot was. I hope it doesn’t cause too much issue.
I’m using a standard bending machine from blues creek.
I’ll triple check before I go to the bender what side is up and stuff.
I mean... it should just be like a standard bend with a preferred outside right
Users browsing this forum: Powdrell1 and 12 guests
